arcadeWC
I am trying to get my Type 3 Chihiro setup for netbooting and having an issue. I purchased a null pic from Mitsurugi-W @for Chihiro net booting and using it at this point - also net booting with a Raspberry Pi that I have used for some time and works well. The games seem to boot fine and everything seems "ok", but at almost the same point for any game - it will reset and give an Error 33 (Gateway not found). In doing some research, it was suggested to be a pic issue, but not sure what to try next as I believe I have the correct one for this. It seems to loose the network connection, even though the game is already loaded and it shouldn't need to be connected to the Pi at all. Is it possible I just got a bad pic and has anyone else experience this? I also want to update the firmware to the Darksoft firmware for SSD/CF loading and I am unable to do it as it attempts to load the firmware via the Pi, but will not maintain the connection and eventually get the same Error 33. Any thoughts would be greatly appreciated!
