FS [NEW MACH BREAKERS 4P ADAPTER] Tailsnic Retroworks custom adapters
Spain
Other selling threads:
Tailsnic Retroworks's Multis thread:
https://www.arcade-projects.com/threads/tailsnic-retroworks-multis-thread.35815/#post-482173
CPS1 / CPS2 / Kabuki openkeys:
https://www.arcade-projects.com/thr...cps2-and-kabuki-from-spain.27544/#post-399629
JAMMA ADAPTERS
CAPCOM Classics jamma adapter with button remapping function and voltage leds. Security "T" included
25€,
IMAGES
KONAMI Classics jamma adapter with button remapping function and voltage leds
25€,
IMAGES
SEGA System 8 jamma adapter with button remapping function and voltage leds
25€, IMAGES
SEGA System 16/24 jamma adapter with button remapping function and voltage leds
25€,
IMAGES
JAMMA / AUDIO ADAPTERS
Alligator Hunt easy stereo outuput adapter. Security "T" included. DIPSWITCH GROUP 2, SWITCH 5 MUST BE OFF TO WORK WITH STEREO OUTPUT
20€,
IMAGES
NebulasRay / NAMCO System 2 easy stereo output adapter. Security "T"s included
On NebulasRay, you have to set the game audio inside test mode.
On NAMCO System 2 game, a jumper near the audio section has to be changed.
25€,
IMAGES
Namco System 11/12 jamma remapper and stereo output adapter. Security "T"s included
You have to put STEREO mode inside the game to the adapter to work properly.
Set of 2 PCBs that allow you to output the complete set of buttons of these systems through CPS1 or CPS2 kick harness format. Also allows you to output 3.5mm stereo jack mode.
Jumpers installed for making the union of 1-2-3 (jamma) 4-5-6 (kick harness) buttons directly, and also 12 faston cables if you want to change button remapping to your cabinet. You can change all of 6 action buttons as you please.
In the third photo, you can see the faston cables installed for changing 1-2-3 buttons of each player to 4-5-6 through kick harness, and vice versa.
Follow the indications of GAME pins (where the original buttons begin) and JAMMA/KICK pins (the real mapping you want).
45€, IMAGES
Mach Breakers (Namco System NB-2) 4 players and stereo output adapter. Security "T"s included
Set of 2 PCBs that allow you to output the complete set of buttons of this system through CPS2 kick harness format using the official cable pinout standard used in games like Dungeons & Dragons / Battle Circuit for CPS2. Also allows you to output 3.5mm stereo jack mode.
Jumpers installed for making the union of 1-2-3 (jamma players 1-2) 1-2-3 (kick harness players 3-4) buttons directly, and also 12 faston cables if you want to change button remapping to your cabinet. You can change all of 3 action buttons as you please.
45€, IMAGES
Universal minimalistic jack 3.5mm stereo adapter.
A lot of models depending of the game/system. Before ordering I mount the exact pcb the system needs and head orientation.
LIST OF TESTED COMPATIBLE STEREO GAMES
DATA EAST
Captain America and the Avengers
Dark Seal II / Wizard Fire
Night Slashers
Thunder Zone
KANEKO
Kaneko Supernova
KONAMI
Cowboys of Moo Mesa
Bucky O'Hare
G.I. JOE
Gradius II
Konami GX
Lethal Enforcers
Martial Champion
Metamorphic Force
Monster Maulers
Mystic Warriors
Premiere Soccer
Run & Gun
Salamander / Lifeforce
Sunset Riders
Teenage Mutant Ninja Turtles: Turtles in Time
The Simpsons
Thunder Cross II
Violent Storm
X-MEN
NAMCO
Namco System 1
SNK
NEO GEO MVS longest
NEO GEO MVS medium
NEO GEO MVS 4 slots
SEGA
SEGA ST-V
SEGA System 32
SONY
ZN-1
ZN-2
TAITO
TAITO F3 cartridge
TAITO F3 single white
TAITO F3 single orange
G-NET
12€, IMAGES
GENERAL ADAPTERS / MISC
CAPCOM CPS3 90 DEGREES Adapter for changing key cartridge position. ENIG material
35€,
IMAGES
Konami Gradius III CPU speed selector
This is a little board for making a little overclock on your Gradius III original game board. You have to desolder the original 10MHz osc and install it in the new board I provide. It comes with a 12MHz osc installed previously.
15€,
IMAGES
Konami 007644 custom replica
This custom is used in many Konami games as an aux buffer: Konami Twin 16 (12 units), Gradius III (4 units), Teenage Mutant Ninja Turtles (2 units)...
15€, IMAGES
Very nice and clean work!! 👍👍
May I ask you which connector you use for your RCA adapters? I made the same kind of adapters to be used in Sega Rally 2 cabinets (here), first with Dupont connectors, but they don't fit all the way down and can detach easily. Now I use JST XH male connector with a female to female cable to change gender.
Works well but I think your solution looks better :)
Stereo adapters added for these list of games:
Bucky O'Hare
Cowboys of Moo Mesa
Kaneko Supernova
Konami GX
Lethal Enforcers
Metamorphic Force
Monster Maulers
Mystic Warriors
Night Slashers
Premiere Soccer
Run & Gun
SONY ZN-1/ZN-2/G-NET
TAITO F3 cartidge and single board
Thunder Zone
Violent Storm
Wizard Fire
X-MEN KONAMI
Pics of f3 cart?
The audio adapter you say? Is like this
How about the TRFightstick case? Will it fit inside?
