'NMK-111' and 'NMK-112' reproduction
caius
Italy
The 'NMK-111' and 'NMK-112' are two custom chips found on many arcade PCBs from NMK manfacturer.
They share the same QFP64 package :
Technically speaking the 'NMK-111' is used for latching RGB output (just before the 'NMK-007' R/2R DACs) and handling palette RAM. It's also used for handling background VRAM.The 'NMK-112' is used for OKI MSM6295 audio samples ROM banking.
Some time ago I sent 'Furrtek' (https://x.com/furrtek) a couple of chips, he promptly decapped and imaged the silicon dies.After some time 'Recreativos Piscis' (https://x.com/Recre_Piscis) identified the cells of the dies making schematics of the internal structure and writing Verilog code of it.The last step was making a proper replacement of the chips, this is what I made using the castellated half holes design in order to mimic the QFP64 package.I chose a small CPLD to embed the logics :
Both replacements worked fine at first try.Here is testing of the 'NMK-111' reproduction as RGB latch on a Macross PCB :
View: https://youtu.be/dRoUz3GVPPA
Here is testing of the same reproduction as background VRAM handler :
Here is testing of the 'NMK-112' reproduction :
View: https://youtube.com/shorts/14BoHLLGxvk
A huge thank again to 'Furrtek' and 'Recreativos Piscis' for their brilliant work without which this result would not have been possible.
excellent work!
always great to see replacements available for these failing customs.
