lowlight
Hey everybody,
This is an intermittent annoyance that I've noticed for a while now (couple of years) with my AtomisWave SD Cabinet's stock TriSync monitor. I'm curious to know if anyone else here has had this happen before, what causes it, and if there is a permanent fix-action for this behaviour.
Occasionally, for what seems to be no discernable reason, the monitor's display will completely shift to the left-hand side by about 1/3 of the entire display. This ONLY ever happens when a direct VGA game is hooked into the cabinet (Sega Naomi, Sammy AW, etc). This behaviour to date has never happened with standard or medium resolution games hooked into the cabinet. What's confusing about the display shift is that it seems to happen randomly; I can't seem to replicate the problem on a consistent basis. What's more, is that it will every so often come/go after long periods of idle uptime (days to weeks), and when it does occur can last from a few minutes up to a day or so until it seems to go away on its own.
Sometimes this odd shift of the screen can be "cleared" by manually unplugging the monitor from the cabinet's internal outlet, waiting for 5-10 seconds (a completely arbitrary time), and then plugging it back in. At first I thought it might be some odd form of EMI in the cabinet or the other surrounding arcade equipment, but the occurrence of the shift doesn't change regardless of where I relocate the VGA cable run within the cabinet. Additionally, I ruled out the additional SUN Power supply as the contributor (Sega Naomi), as this problem occured when I was still using the cabinet's in-built JVS harness.
Any ideas/suggestion/solutions are welcome. As I mentioned in the beginning, this is more of a mild annoyance than anything, and I really want to know more about why it happens than anything else, as I've never seen it before in any of my other VGA arcade equipment (Crazy Taxi Sit Down, Gauntlet Dark Legacy, etc).
