doozer
Brisbane, Australia
Does anyone have a copy of the Outrun 2 SDX wiring diagram?
This is the one with dual steering wheels.
The Hummer Extreme MDX diagram would also work as its a very similar setup.
Every PDF I have found for Outrun is badly scanned and you can't read the diagram.
The Hummer ones don't include the diagram at all.
Thanks,
Matt.
winteriscoming
Indiana, US
Specifically what are you needing to reference?
Would it be significantly different than ID4? I can't recall if that one has a good wiring diagram.
IIRC, when I briefly booted the Lindbergh versions, the controls worked on my original OR2SP (Chihiro version) cab, so if you're just after controls, that one might be good enough.
doozer
Brisbane, Australia
I'm interested to see if there are multiple FFB boards, connected via the 838-14597 motor switcher board.
I'm still digging into the 4 byte versus 7 byte feedback packets and need to recreate the official setup with dual steering wheels.
