Apocalypse
New-Zealand
Hi all,
I've made a small hack for OutRun to have it display which gear is engaged with the same look and feel as the Saturn or Sega AGES version.
Useful when:
- you don't have the real cabinet but use a JAMMA adapter (mine has a D latch to toggle between LOW/HI gear)
- you don't want MAME to display the lever position as an overlay (looks a bit out of place)
- you're using a box or pi based emulation thingy and can't enable overlays
View attachment GEAR HACK (LOW - HI).zip
AlxUnderBase
Constanta,Romania
Hats off in front of you sir ! I don't have the OutRun but when i will get it , for sure i'll put these into it . Thanks for all what you've doing for us ^^
nonosto
FRANCE
THX buddy
test with canonball windows. Run perfecty with one button gear, but dont run with two botton gear set . I dont know if it's fixable.
Apocalypse
New-Zealand
@nonosto 2 buttons? How does that work?
The gearstick is wired to a single input.
What is the behaviour you experience with 2 buttons?
nonosto
FRANCE
THX
you have one bitton fot H and one for L, in my set on saturn X = L A=H. It's same thing for sequantial in OR2 in xbox.
with 2 button H and L dont appear on the screen, just like original.
one example but with L & R button from saturn:
Apocalypse
New-Zealand
THXyou have one bitton fot H and one for L, in my set on saturn X = L A=H. It's same thing for sequantial in OR2 in xbox.
Then not a bug, it's how I intended it to work since the arcade version always uses a single input.
The game has no way to know you're using two separate buttons, it will always read the "result" sent by the emulator on the dedicated gear shift input.
If you use two buttons then simply use the normal romset.
nonosto
FRANCE
Then not a bug, it's how I intended it to work since the arcade version always uses a single input.The game has no way to know you're using two separate buttons, it will always read the "result" sent by the emulator on the dedicated gear shift input.
so it's seems exist some cabinet with two switch:
Apocalypse
New-Zealand
Official cabinets? Pics please.
Still it doesn't change the fact, whatever the wiring, it ends up on a single input on the PCB.
MAME only allows me to assign one button.
[EDIT]
If you took it from the Cannonball manual, it's obvious they did it in software.
