Hello,
I'm trying to repair an Outrunners pcb that has no sound:
The test reports ic21 bad: it's the mb8464, the ram next to z80. I tried to replace it with another one but no change.
The other things I checked so far:
- the amplifier works fine,
- the z80 address and data lines are toggling fine, clock pulsing, reset high, bus rq high, nmi high. Did I miss any pin to check?
- Audio Eprom epr15550 is a 27c040 and checks fine against related rom file. While data, address lines and Output enable toggle correctly, chip enable is low. Is this normal or not? Because I read that both OE and CE should be high.
Any hint would be appreciated.
Thanks
Makedome
Thanks
Makedome
