Pana Twin Long Kick Harness Compatible?
jumpman1229
Maryland
Is it possible to hook up a CPS1 kick harness to the Pana Twin Long or other similar Japanese "control boxes" or superguns? In this model, there's an external connector port on the back, but after taking it apart, I see these are for the mahjong controls. I do have a JAMMA extension made by @RGB which has a kick harness connector on it, but I'm not sure the Pana to JAMMA harness supports this. Any hope to not be able to just punch on my Street Fighter II board?
I have a Pana Custom Long and it does not have a kick harness connection. Buttons 4,5,6 are setup to the jamma connector. You would have to get a jamma extension cable that is specifically made for the supergun and has a kickharness adapter to hook to board. The one i have came with the Pana Custom Long supergun i got. See pic.
Very cool! Where did you get yours from?
@jumpman1229 I got mine from yahoo japan auctions. If you keep an eye on it sometime they show up and you can snag yourself the ext cable for it.
Nice, I got mine there too. I actually just looked at the included Pana to JAMMA adapter and realized there's solder pads for player 1 and player 2 kick buttons. So I thought I would take the included mahjong cable (since I don't plan on playing any mahjong games haha) and ripped out the 2 ground wires since the other wires are already in the proper spot. I then removed the cables from the connector on the other side and soldered them to the Pana end of the board following this pin out:
https://wiki.arcadeotaku.com/w/CPS1,_CPS2_&_CPS3_Connectors
I attached the pics of the final product. Tested it out and everything is working great! Thought I would document this in case someone gets needs help with this in the future.
Very nice. Yeah that how mine came wired up. Glad your good to go know. Have fun with it.
