SOLD PLEASE DELETE
As far as I know the MS9 are the same, so you should be able to widen your search
I don't think so... The holes might be the right spacing, but the part that holds the chassis is definitely different between cabs.
I had an older thread asking for some too. I'd like to get at least one.
I was wrong, a Astro MS8/9 frame will not fit on a blast. but a blast frame should fit an Astro.
So, I just came into possession of a MS9 frame, you are right the chassis mount is different, the spacing between the 2 arms of the frame a is different, I think this would be easily remedied by drilling a couple of new mounting holes though.
However, the kicker is that while the blast frame(Ms2931) has mounting holes for an Astro (Ms9/8), the Astro frame does not have holes for the blast, so no dice.
Yeah, the Blast is the odd one out. Every other 29" Sega cab has mounting pegs for the round holes (Astro, Versus, Naomi Uni / Net City, sitdown racers, upright cabs, everything).
No idea what brain fart they had designing the Blast.
