Epyc
CA, USA
Great work @RGB! How can we go about preordering the new HAS revision?
touche112
Michigan, USA
No pre-orders this time, I'll put them on sale in waves sometime in July so that they don't sell out in the first day. More information soon.
Awesome! Can't wait!
RGB
Europe
It's got the same features and functionality, but I changed a few things:
- The microcontroller is in DIP case, socketed
- DIP switch instead of numerous SPDT switches
- The voltmeter is mounted differently
juanmiglesias
Winter park, Florida. Zip code 32792
Hi there, quick question, are you going to use this thread or create a new one?
Animaitor
Japan
@RGB, would it be possible to add 2 knobs on the HAS to control the V and H position of the image for non arcade CRTs as seen here? I could buy the one from Aliexpress but I rather pay to someone who knows what he's doing and that can deliver quality stuff. Maybe add it on the JAMMA extension harness?
roy
Israel
does 8pin mini DIN connector for audio and video output means i can use my genesis 2 scart cable?
what power supply is to be used with this 6 pin connector?
Stupid Dufus
Tokyo
The Genesis 2 uses a mini din-9, so it wouldn't be compatible.
As for power supplies, there is a thread about various arcade power supplies to use here: Budget Arcade Power Supplies
When you purchase a HAS, a power cable is included to hook it up to a screw-terminal power supply like those in that thread.
roy
Israel
can you recommand where to buy mini din 8 pin cable?
since my setup is with crt/pvm i cant use arcade power supply so i guess a pc psu will be ok for most arcade boards,
am i right?
Stupid Dufus
Tokyo
I personally ordered mine from Retro Access (US), but Retro Gaming Cables (UK) makes them too. I'm sure there are more sellers people here will chime in about.
I'm not sure I understand your concern with a CRT. I have mine connected with a meanwell PSU (from that thread), and I've connected it to a PVM and two different BVMs without issue. It doesn't have to be a PSU taken from the inside of an actual arcade cabinet. Just needs to be able to provide 12v and 5v to the HAS to properly power it and the arcade board connected. And a few older boards might require -5v as well.
roy
Israel
my concern is using arcade power supply with exposed terminals out in the open where my children can reach...
that's why I prefer more closed protected pc power supply or other solution if exist
