Problem with astro city PSU
kernelchagi
Madrid
Hello. I have this weird issue were i cannot get my jammatopi to work on my astro city.
The psu is measuring 5.25v exactly when i load it with a PGM pcb, but if i connect nothing, the voltage fluctuates somewhere between 4.4 and 4.8v.
If i connect a raspberry with the jamma to pi the 5v voltage fluctuates between 2v and 5.25v very fast and i dont know whats happening.
The psu is fully recap, i tried to change the potentiometer and the IC3 with same result.
The raspberry and the jamma to pi are working because they work perfect on my blast city.
And this same cabinet worked good before with the jamma to pi and the pi3.
The model of the psu is the 400-5198-01Y wich is known for having incompatibility with cv1000 games but i dont know why¿?
Any ideas? Probably the next i will do is check the transistors.
That’s way too high. You can damage ICs with any voltage above 5.1v.
Is IC3 the 5v line voltage regulator?
I dont have the schematics but the ic3 is a voltage regulator that is connected to the potentiometer.
yep. You can put a high resistance directly on the 5V line of he PSU
A friend soldered a car lamp on his PSU and it worked with Cave and Pi carts then
New to this forum and happy to see someone else ran into the exact same issue I'm having on my new-to-me NAC. Same power supply (400-5198-01y), fresh recap, adjusted to 5.05V and functions perfect with a PGM plugged in. Trying to run a JAMMAizer w/ a Sega Saturn.
Is there a non-intrusive solution here, or a picture/diagram showing how I can wire up some load? I'll most likely run dedicated PCBs in the future so I don't want to solder a resistor to the board if it causes issues down the line, but I may just be misunderstanding what you guys were suggesting.
Thanks for any help!
Hello. I solved the issue powering up my sound amp from the jamma harness. I bought a male-female jamma and soldered a wire to power the amp from there. You can also solder a resistor or an hallogen bulb (they work with 12v) there and it will work the same but it will heat it up a little.
Hello!
I stumbled upon this issue as well at my friend's place last weekend.
This is related to the 400-5198-01Y PSU inside a New Astro City.
I tried different resistors as a load on the +5V rail and concluded that 8 ohms (8.2 in my case) was the sweet spot. 10 or 12 ohms didn’t draw enough current for the PSU to turn on.
So, according to Ohm’s Law:
5V / 8Ω = 0.625A
5V × 0.625A = 3.125W
I therefore ended up choosing an 8Ω, 5W ceramic resistor. I applied some thermal paste and pressed it against the frame, then soldered it in place.
It’s been running for about 30 minutes now, and although the resistor generates some heat, it’s only slightly warm to the touch. 0.6A should be low enough to leave room for connecting a more current-hungry PCB. The PSU can deliver up to 7 amps, so I believe this setup is fine.
Now it can run CV1000 games!
Hello!
5V / 8Ω = 0.625A
Thanks for reporting on this... I'm thinking about including something like this on a passthrough board.
