VenomXL
US
Does anyone run a IGS PGM in a Dynamo HS-5?
My Raiden Fighters 2 is my primary shmup cab, and given the weird design on the Dynamo HS-5’s drawer, it doesn’t give much clearance to mount the board cartridge slot up with the PCB feet under it.
Was curious if anyone had any better setup options than putting it board up with the cartridge slot upside down and using long screws to hold in place with the PCB feet upside down?
VenomXL
US
This is sorted. It can’t clear the top of the cab if you mount it in the back but it’s fine in front, so I just swapped Raiden and PGM.
