mathewbeall
WMMT
Ok - here is a image file that I have modified from @chunksin PiforceWeb 1.2 fork of piforcetools. This is the one with a nice web interface and also had the card emulator already set up and good to go...
The modifications I made are all towards making it as easy as possible to run a WMMT1/2 cabinet with a dedicated tablet and make it really easy for people to use cards electronically. I tried to keep track of the files I changed and they are listed below.
Upon bootup the image is in "single" mode - so it loads up WMMT1 and also loads a temp card, so that the card reader boot test passes. After the boot test passes the card is "ejected".
After the game boots - connect to "naomi" as the SSID and "segarocks" as the password - then just go to any webpage (I use a.com). My version defaults to the cardemulator page (although the full menu is still available).
It's hardcoded just to show WMMT cards, and also allows you to create a new card (like the original PiforceWeb). Once you either load, or create a card, the screen will then show you what card is active, and starts polling to look for an eject. Once you finish your race and say "no" to continue, then within 10 seconds the screen will change after it detects the card is deleted and let's you select another.
Below is the mega link for the image - it's sized for an 8G card. Feel free to download and modify to your hearts content...
no warranty is implied!
**NOTE** ensure your Chihiro is set to ip address of 10.0.0.1.
mega.nz/#!9mBWnASQ!Tpg6jmsKard…khcuERunfzbhbOUSdEZDrEy0c
(changes to base image)
added /var/www/html/ejectcard.php
modified /var/www/html/cardemulator.php
modified /var/www/html/launchcard.php
added /var/www/html/PHPBackgroundProcesser.php
modified /sbin/piforce/check.py
Changed ip address of raspbi to 10.0.0.10 - Chihiro should be 10.0.0.1
turned off access logs for webserver (don't want disk to fill up).
