As the title says. If you could share your wisdom I would be grateful. CPS1 boards are very tight and I want to avoid damaging them when working on mods and case.
I use my fingers and pry gently one corner at a time, working my way around each corner clockwise or counterclockwise. I use one hand to brace the lower board underneath and the other hand to pry the upper board away from the lower board. After a few passes, each corner should pop free.
