XeD
Symptom: Boot to garbage
I picked up a non working cps3. The description said it was previously worked. I just figured the seller was just talking about the factory repair on the rev 2 boards. I Installed my superbios cart and got garbage on screen (the screen sometime you get with no cart inserted). I clean the cart slot with some Deoxit. Brushing it with a brush and some lint free paper. Booted to garbage on screen again. Inspecting the board closely I notice some corrosion around the watch dog ic (HA16103). I removed the IC and was greeted to what smell like mice urine. Seem like someone wash the pcb. Clean it up with some alcohol. Jumper pin 19 (stby) on the ic to pin B29 on the cart slot. Booted it up and it works. I'm going to shelf it for now until I can get some new solution for my ultrasonic cleaner. Just t o make sure I can clean any reminisce of the mice urine anywhere else on the board. Unless there is a faster way?
