JohnRambo'sKnife
Wish I had your troubleshooting knowledge. Impressive to say the least.
Absolutely! I didn’t mention it in my write up, but I tried swapping the two ribbon cables between the malfunctioning M72 board set and my working board set early on. The cables are good in this case.something i learned early on - dont trust ribbon-cables.
Yeah that makes sense. Glad you brought it back to life.My assumption is that either the power supply got turned up way too high, the power supply failed catastrophically, or the JAMMA harness was plugged in upside down.
Fantastic work!The KNA6034201 reproductions from @caius arrived and FINALLY the board set is working 100% with no jailbars!
I ran the board for 24 hours as a "soak test" just to make sure that everything was solid. For good measure, I tried swapping in each of the original KN customs one at a time just to see if one of them was good, but unfortunately both custom chips have issues.
In the end, I ended up replacing 14 failed chips across both the middle and bottom boards.
One more update to come after I program, install and test the M72 Multi!
There's also that awesome blog:
