Revision A Tornade cart not booting after ultra bios conversion.
cruzlink2
Brooklyn, New York
Got this new generation cart I was converting for a friend that won't boot. At first it would do nothing, after I reflowed the CPU it seemed like it was trying to boot but would reset. Now I had ordered the two nand gate chips, I received one and swapped it and now it doesn't reset but just shows a solid color screen
View: https://youtube.com/shorts/nYM5-lQpEhU?si=heT70rIQVim-gHBH
View: https://youtube.com/shorts/eQPiS1xBJBI?si=CuF6Aat1EwqgUJqy
View: https://youtube.com/shorts/GL1Ujrcj9gA?si=AgxDazp5zfVSvZrU
Could the crystal potentially failing be a culprit? Otherwise I’d check the wires on the back of that A to make sure they’re not crossed/still connected.
Wires are good. Any idea where I can purchase the oscillator? I know they have to be available since the repro cart use them.
Got a parts Saturn here gonna steal one of the CPU put it in the cart and see tonight.
So I have a revision D cpu cart with the same symptoms and I replaced all the same things I replaced on this card and it still won't fire up at all, with that one I suspect the oscillator. @Darksoft do you have any of the oscillator you use on the repro carts left? I would not mind buying one from ya, can't seem to find them on the net.
