Grinning Cat
One of only 9-10 HAS 1.0s out there, according to RGB
Full info on this model here: https://shmups.system11.org/viewtopic.php?f=6&t=52894
This first model comes with a Phihong external PSU (which I think was discontinued before other HAS batches). It's good enough to power most single layer PCBs, and anything that isn't too power hungry - I've had no problems using it for Cave stuff and even CPS1/CPS2, etc. Although obviously anything that needs -5V is a bust. As with other HAS models, you can also connect it to an arcade PSU...you either need to make a cable, or you could buy the Axun external PSU https://www.axunworks.com/product-p669351.html and buy a HAS cable from there.
The Supergun was sent back to RGB at one point, so that it could have a resistor added to the sync line. The original design was TTL sync only - but the resistor attenuates sync to 75 Ohm, so it's now safe to use with an OSSC, Scart switches, etc.
Supergun is basically in perfect condition - still has the peelaway plastic on the perspex
Pictures here: https://www.dropbox.com/sh/bgurkvgoxp4fhz4/AABg7KrCo42mhRT5lWUlAMTOa?dl=0
Comes with:
- RGB Scart cable w/ 3.5mm pigtail (also made by RGB)
- Phihong PSU (will include a kettle lead for any UK buyers)
- ArcadeForge SNES to Neogeo Supergun MAK Strike Gamecontroller Adapter w/ perspex case (although keep in mind you actually need to remove the perspex case on this to use it with the HAS)
- PDF of the manual
** SOLD** Looking for £150 + shipping. **SOLD**
Payment by PayPal Friends and Family or Goods and Services (+5%).
Happy to mark down the value on Customs declaration for non-UK buyers – but I can only insure for whatever it is marked at on the Customs. And anything not fully insured will have to be PayPal Friends and Family-only.
Comes with:
- PDF of the manual
