Darksoft
Poland
Sometimes those programmer have one option to "Slow Program". I would activate that if you haven't done it yet.
But IMO the most probable cause is that those eproms are a bit old and may have it's own timing / sequence depending on the brand when being programmed.
AlxUnderBase
Constanta,Romania
@nonosto ... this is how i writed mine.
by the way sir ... how you managed to write the A4 rom ? did you have an adapter who is able to write non-jedec eeproms like 27c301 or 27c100 with your TOP3000 programmer ?
nonosto
FRANCE
thx I have a more recent topall.exe, and I dont find your ref,, could you share your program version, about non jedec 27C100 II fond thiss chiip on the bloxeed rom board, is it good?
AlxUnderBase
Constanta,Romania
yes , is good -> 27c100=27c301 . But to can write this non-jedec eeprom with your top3000 , you need to modify internal your programmer or you need an special adapter ... @pacoarcade has released one (Check that theard)✌️
nonosto
FRANCE
I will buy it. Could you share your software ver or iso from the mini disc please. My ver. dont support 27C2001
nonosto
FRANCE
finally ssome succes burned with top 3000 and other with cheap TL866. Waiting non jedec adpter.
nonosto
FRANCE
I have a very special graphic bug. I am pretty sure after check burn is good.
playero
Seoul, Korea
Did you find the answer about Background Graphic is broken?
I tried to convert Shadow Dancer with Clutch Hitter pcb, and I have a problem like you.
playero
Seoul, Korea
Unfortanenny not.
An expert in my country, fixed this problem.
see the pictures.
He said, This pcb doesn't have patterns on some sockets, So need to wire some points to work B1, B2, B3 sockets properly.
Anyway, it works now.
nonosto
FRANCE
see the pictures.
Wonderful thx so much, same fix for moonwalker?
Curseur
Bordeaux, France
Many thanks to Apocalypse for the patched roms and Playero for the tip.
I had the same issue on my Clutch hitter daughterboard which is a 171-5987A, adding 3 wires did the trick and fixed the Shadow Dancer backgrounds:
playero
Seoul, Korea
Good Work!! Thanks!
ic3b4ll
Porto, Portugal
I had the exact same problem and actually thought my ROM board was bad. The 3 points where the wires are supposed to go are connected to the OE pins on the 3 affected ROMs. They are also going to the big custom thingy on the ROM board which (unless I'm mistaken) basically takes care of the banking of the tile and sprite ROMs enabling the use of more GFX data.
Of course, other games using this specific ROM board can access data there which would mean the address latching data being fed to the custom is not enabling the affected ROMs.
I'll try and look at the memory maps of games using both ROM boards and check writes to the address space of the custom to see if something is missing from the patch.
This will happen in the future so Terms and Conditions apply ;)
