Sanwa Joystick In a OK Baby Cab
Brentradio
Las Vegas
Is there anything special I need to do to use a Sanwa Joystick with the 5 wire connector in a OK BABY jamma cab?
I hook up the joystick and connect the 5 wire connector to the joystick and the 5 wires to a molex connector going to the jamma connector. If I touch the wires together (ground and red for up) at the molex connector, everything works fine. Move 4 way and fire both buttons. But when it's connected to the 5 wires and to the joystick, nothing happens on the joystick.
Brand new sticks, swapped out each joystick and both 5 wire connectors, same thing.
Not sure what to do.
Just after I posted this I found out the 5 wire connector needed to be redone. All is working now.
