SCSI to SD Adapter (SCSI2SD) V6 issue (as CDROM replacement in CPS3 Darksoft multi setup)
Pinball
Old Blighty
Hi guys,
I recently bought a CPS3 system with included Darksoft multi and CDROM/Darksoft disc. All works fine.
As a backup for the CDROM drive failing in the future, I bought a SCSISD from the Amiga Store (http://amigakit.amiga.store/product_info.php?products_id=1314). Copied the CD onto a FAT32-formatted 32GB Sandisk SD card, and connected the SCSISD board in place of the CDROM drive. On booting up I then got the error message: "You have inserted an invalid CD-ROM" (see photo).
What can I do to fix this?
Many thanks guys!
Did you follow these instructions when making the SD card? Make sure you upgrade with the latest v6 firmware and not the one linked in these instructions.
PLUG THE MICRO SD CARD TO ANY EXTERNAL SD CARD ADAPTER AND PLUG EXTERNAL SD CARD ADAPTER TO PC
download SD Card Formatter from below website
https://www.sdcard.org/downloads/formatter/
INSTALL SD CARD FORMATTER
LAUNCH SD CARD FORMATTER
USE QUICK FORMAT TO FORMAT THE SD CARD ( please do not format the wrong drive ).
download HD Raw copy tool from below website
https://hddguru.com/software/HDD-Raw-Copy-Tool/
I downloaded this one
"Download Windows Executable (works without installation):"
download the CPSIII games in .ISO format from below website :
http://www.mediafire.com/download/p8eieg5zz47rmk6/UniCD-CPS3_for_custom_SH2_V5.7z
I believe you need to unzip the downloaded file to get the .iso FILE
LAUNCH HD RAW COPY TOOL -> FILE -> SELECT THE .ISO FILE
SELECT DESTINATION TO COPY TO.
CLICK START BUTTON
HD RAW COPY TOOL WILL START TO COPY THE ISO FILE TO THE SD CARD
AFTER THE COPY IS DONE, YOU CANNOT VIEW THE CONTENT OF THE SD CARD. WINDOWS WILL SHOW A ERROR MESSAGE IF YOU CLICK ON THE SD CARD
download from below link the latest firmware
download from below link the latest software to update the board's
firmware and settings
http://www.codesrc.com/files/scsi2sd/v4.8/
I downloaded the latest firmware for windows 10
I downloaded the latest update software for windows 10
please download the appropriate software for your own OS
RUN SCSI2SD-UTIL.EXE -> SELECT THE DOWNLOADED FIRMWARE
IT WILL AUTO DETECT THE CURRENT FIRMWARE IN THE BOARD
-> FILE -> UPGRADE FIRMWARE
IT WILL AUTO UPGRADE THE FIRMWARE
GOT WINDOW TO SHOW FIRMWARE UPDATE STATUS
AFTER SUCCESSFULLY UPDATED FIRMWARE CAN SEE THE LATEST FIRMWARE NUMBER
WHILE THE SCSI2SD-UTIL.EXE IS STILL RUNNING
SEE THE 2 PHOTOS SHOWN BELOW
https://lh3.googleusercontent.com/-...ghIaChHyzrX-ABLTwCCo/s800-Ic42/SCSI2SD-02.png
https://lh3.googleusercontent.com/-...e9DYUlmghgaJyrS1QCCo/s800-Ic42/SCSI2SD-01.png
AND MAKE SURE ALL THE SETTINGS ARE FOLLOWED EXACTLY
ONCE DONE SELECT -> FILE -> SAVE TO DEVICE
IT WILL SAVE THE SETTINGS TO THE DEVICE
DONE
UNPLUG THE USB CABLE THAT CONNECT THE SCSI BOARD TO PC
UNPLUG THE USB CABLE FROM SCSI BOARD
PLUG THE SD CARD TO SCSI BOARD
PLUG ONE END OF THE CABLE TO SCSI BOARD
PLUG THE OTHER END OF THE CABLE TO CPSIII BOARD
NO NEED TO PLUG THE MOLEX TO THE SCSI BOARD OR CPSIII BOARD
WHEN YOU START THE CPSIII PRESS AND HOLD PLAYER 1 START
NEED TO TEST TRY TO OVERWRITE A GAME TO THE CPSIII BOARD
Thanks djsheep. Full SD card prep then. Will do.
Naively, I thought I could just copy over the CD, heh.
You gotta change some settings on the actual SCSI2SD device itself so it knows how to read the SD card as an emulated drive. See how you go and chirp back in if it works.
I've just completed this. Currently rewriting a game to test, but it looks fine.
A huge thank you to djsheep for your clear, detailed instructions!
I'm going to stop using the CDROM for now even though it works.
