SCUBA King
South Lyon
Cleaned, tested on my 16b.
Suped up custom labels to make it look cool AF.
This will run with standard Z80 and 68000 on 16B PCB.
**If your main PCB has an epoxy block at position D15, remove and replace with a standard Z80, audio will not work if you don't.
If you are still running encrypted roms/cpus, to make your PCB work with this it needs to be setup for unencrypted romset.
Remove the FD1094 Epoxy CPU, replace with 68000 12mhz CPU. If there is an MCU installed at position C2 on your main PCB remove it.
*You can change region by using different decrypted CPU rom sets. Replace the CPU roms IC1 and IC2 from the mame rom sets "goldnaxejd" for Japan region or "goldnaxe1" for world, currently installed is USA version.
$165 shipped PPff
$70 extra for goods and services?
Removed gs option. If I need to offer gs I can put it back in.
On other forums I am used to selling on you can't list with FF only, cant find any rules here that state the same.
If there are, no problem, I can add it back again.
