Sega 837-14505 IO board. Is is possible to reverse some inputs so they are "active low"?
MickyMac
Europe
There are 4x IR sensors around the base of the Afterburner Climax cabinet that are supposed to stop the cabinet movement when someone steps on the base.
The problem is they are "opposite": always sending the "on" signal to the IO board until you block the beam then it sends the "off" signal to the cab (The opposite of what should happen).
All other input buttons are fine: gun, missile, start.
They are wired to the 837-14505 IO board 60 pin connector:
Right sensor: pin 34
Left sensor: pin 36
Front sensor: pin 38
Rear sensor: pin 40
Is there some way to reverse these on the IO board?
