Sega - Control Panel Glass Retainers
PASTBLASTER
Florida, USA
I have a Naomi Uni cab that did not come with the Glass or Metal Retainers that hold the glass in. I was wondering if anyone had a file for the retainer (Left and Right would be needed) before I cad one up. I know the stock ones are metal, and bend a bit, but I am thinking something could be cadded to work.
Anyone got anything?
I'm highly skeptical that you could get the strength you need from that thin of a plastic part (3D printed or otherwise). especially because for it to function you need to be able to thread a screw into something less than 1mm thick and have it hold a 10lb piece of glass.
granted the part is not normally under stress but I'd be afraid of it pulling out whenever I open the panel.
If you're after the original parts you might try videotronics uk. I've ordered the instruction glass and holders from them before. failing them Yaton is probably your best bet.
  • Like
Reactions: nem
