XianXi
Honolulu, HI
Is the Naomi the only system fan that has to be altered (length and connector)? I'm trying to round up a bunch of fans for Lindberg, Chihiro, Naomi, Ringedge etc. for a customer. I saw a few posts but they didn't mention anything about length or connectors having to be changed so am I correct in assuming everything was plug and play as far as system and CPU fans?
Any help is appreciated, just want to make sure before I ship them out.
XianXi
Honolulu, HI
I've seen threads that people have changed them so I know some people know.
Aaronr33
Canada
Order replacement fan with same connection?
I.e. ringedge power supply uses a 2 pin 12vdc. Its the loudest fan so i replace with noctura quiet fan.
XianXi
Honolulu, HI
Right, that's why I'm asking, I don't have any of this hardware so I can't confirm it myself. I asked him for measurements and connector types but no answer so I might just have to send them out as is.
Aaronr33
Canada
Noctura will have 3 wires two for voltage and one for rpm. RPM is not needed for power supply so you will use only two wires.
Just need to splice the old connector to new fan wiring. If you have it wrong fan will spin backwards.
