Sega I/O connectors
GTO77
DFW TX, United States
Hi Everyone,
Wondering if anyone knows the connectors name/size for the wires that go into the 60 pin connector? Additionally, what is the housing plug for the connector for the other end of the wire? Lastly, is there a removal tool for these? Any help in tracking these down would be appreciated. I'm trying to rewire some things and I'm having some trouble with these.
The 60-pin connector is a JST RA-6011, the pins are JST RA-SC1290. Removal tool for those, you don't need. Small flathead screwdriver, lift up the tab and you can pull them right out. Unsure what you have on the other side of the wire, probably something going into your control panel, like AMP UP?
Thank you! Yes, it is an AMP UP going to the control panel. Is there an easy way to remove those male AMP UP connectors?
