Sega System 16B CN1 connector replacement
pacoarcade
Spain
Hello, I have a Sega System 16B board with a broken pin in CN1 connector so I'm looking for a replacement. Do you know where can I find it, or the specifications of the connector to look for it?
If the pin is on a side good chance it's a power pin (either +5V or ground). In this case you don't need to replace it since multiple pins are used for power.
If it's actually used for a signal then swap it with one of the power pins from the sides.
