Sony Trinitron CRT repair composite output
VodkaGobalsky
San Jose, CA
My composite output from the back of my CRT stopped functioning all of the sudden. The front ones still work. What would be the most likely reason for this? Is there an easy way for me to fix it?
did you drop it? Probably some cold solder joints somewhere. You could try putting a voltage meter to both the front and the back to see if it matches?
My guess is cold solder joints too. They can crack after years of force plugging cables in and out
