Hey Everyone! I have been having some very strange audio issues with my ZN-2 boards and so it was recommended that I post my issues here and ask for help.
I'm getting no audio from either my SuperGun (Jasen's Customs MK30 ADCAP) or the Stereo Header directly on the ZN-2 board. Unless I plug my Stereo Header board (Everten ZN-2 to RCA) into my PS Audio Sprout box line in jack using an RCA to 3.5mm cable, and then unplug that same RCA to 3.5mm cable from the Sprout box after turning on my SuperGun. After that I get sound on both my SuperGun through the JAMMA edge and the stereo header connection. As an aside, I also can't get sound through the JAMMA edge with the board(s) and the setting(s) set to mono. Only using the Stereo workaround above has done anything at all.
From what I can tell, this is a jank way to get audio to work and it's also defeating the audio circuit on the ZN-2 somehow, but I can't seem to get any normal method to work.
I have replaced the HAPP power supply in my SuperGun to a MeanWell 125 Power Supply and that didn't fix the issue. I bought another ZN-2 board that has been confirmed as working just as a sanity check as well.
I have run out of ideas to get audio working properly and am looking for some help and direction.
Thanks,
ZXRyuu
Thanks,
ZXRyuu
