Splitting vga single but keep brightness up with no lag
DJLC
Saint Louis, Missouri
I am in need of a solution for splitting a 31khz signal for 2 cabs using a basic db15 dsub slitter but the picture is dim on both cabs at once. Does anyone have a solution for splitting the image and keeping the brightness decent for both monitors with no extra lag? I don't want any post processing, just signal amplification.
You can also use an Extron DA2 if you want a simple split without the RGB interface. The P/2 DA2 is probably the simplest (and cheapest) with a hardwired power brick and hardwired VGA input cable.
