SSV PCB R47-181 Replacement?
MmSadda
Columbus, OH
I've got an SSV PCB (nothing fancy - Eagle Shot Golf) I had used to test a cab with a wiring issue. Long story short, there was a short, and I believe it smoked up an R47-181-TDK, who h I believe is a color driver or pre-driver transistor/scr (I could be wrong on that.) Doesn't look this is a commonly available component, but does anyone happen to know of a suitable replacement, or have a source for one?
that should only be a passive RC filter,
to test you can bridge the input and output 1-3.
1 input
2 GND
3 output
please check before,
without warranty ;)
Got it, so you're saying I can just bypass the RC filter to test everything else still works (and as a dirty hack on a permanent basis?)
I may be assuming too much, but the smoke came out of that piece (see the toasted one toward the top of the pic, toasted on the right side.)
correct,
if a color is missing, the color driver transistor Q1 is probably destroyed..........
