MissionFailed
So, i was inspired by every ones projects and decided to learn more about simple prototyping. Downloaded "ExpressPCB" and took last Saturday teaching my self the basics and made my first personal project.... I think.... Its a work in progress. If you have any ideas or see any problems please let me know . Any information would be valuable and vary much appreciated. If this docent work, that's fine. I'll just scrap it and start over. I just wanted a start point and an image to get my idea across.
Project Goal : Have the controls of (x) home game consoles and/or arcade pcbs, to One stander 2player arcade control panel. With the least amount of wires or need for unplugging/plugging/exchanging cables. Smallest foot print possible for the condensers board.
Example 1 :
Namco 359, Lindbergh, type x2, xbox 360, -to-> Controller Condenser -to->
--> [(1)db37 to (2)db15] -to-> (2) RGB's Sega Saturn to JAMMA joypad converter- to -> Virtua stick Pro
Example 2 :
(on shelves next to a blast city = Naomi, ps2, wii, namco 246)--> Controller Condenser---> controller condenser inside arcade cabinet with installed namco 256 pcb controls connected ----> blast city control panel
Design : based off Mitsurugi's Capcom cps1/2/3 kick harness condenser. I was looking around the internet for a full 2player controller condenser solutions for a Virtua stick pro, and all i could find was a db37 5-way switch box. Not bad at $70, but I wasn't interested in stacking a bunch of switch boxes. I wanted something clever, non-visible, with least amount of wires. Looking at Mitsurugi's board i was curious if i could eyeball it and expanded it to 34 leads and stackable. though it would be a simple project to learn prototyping software.
- this board is for jamma to db37 connector standard. I went with db37 connectors because i thought it would be cleaner than having a bunch of jamma extension harnesses or ide cables strung about. It can always be change later if need be.
Larger Photo
Bottom side Photo
Top side Photo
There are a few mistakes. Most notably, I think the diodes are on backwards.
I flipped a group of them to arrange them at one point, and forgot to fix them. I wanted to post the idea and try to get some feedback be for going any further. I was originally thinking of having the boards fit together stacked with interlocking 10 pin male/female connector, but i think that doesn't leave enough ceiling room for right angle db37 connectors and/or 40 pin right angle ide connectors used for the left/right "in" controller throughput. Miisalo's st-v Screen kit has some sweet metal raiser post in his build. I'll have to try to source thous.
- For ps2/3/4, xbox/360, dreamcast, and wii, I'm thinking of changing the db37 connectors for 40 pin. Putting the condenser board in a box with those system controller pcbs. So only to have one db37 or smaller in from all systems, and one db37 condenser chain out to another control condenser chain or control panel.
- For Nes, SNes, Genesis, Saturn, Pc Engine
-turbo switches)? Their controller board circuits look simple enough to replicate directly on the condenser board , eliminating the need for the actual controller pcbs. this should save a lot of space and wouldn't be too difficult to redesign the condenser board to fit them. I'm think i could fit 2player Nes, Snes, and Pc Engine male controller plugs on one db37 cable
(left side) and Genesis and Saturn 2player controls on the other (right side) with a db24.
Once i get all the bugs knocked out of this board. i'll start working on the retro console condenser board, and the modern console condenser board. This was at the least a good intellectual exercise, hope i don't sound too much like a nutter
Any help, advise, or ideas, would be greatly appreciated. thanks for you time.....................(>'.')>
Example 1 :
Example 2 :
Larger Photo
Bottom side Photo
Top side Photo
