hatmoose
This was a case design that I did for a buddy.
He wanted to use one of those massive Extron crosspoint switches with his scart gear like this. This requires a large number of SCART to BNC adapters, normally with audio breakout and sync stripped using n LM1881
https://www.reddit.com/r/crtgaming/comments/7p92ux/my_sync_stripping_tower_of_power_introducing_the/
The device itself is here on github
https://github.com/bentika/Open-Source-Sync-Stripper
Case looks like this
What he wanted was a case that could stand alone, but also stack with other cases to form a "tower of power"
The case itself is really simple, comes in two halves, stacking is achieved by screwing the bottom half of the case into the top of the one above. For easy disassembly I designed the case so the PCB clips into the top half.
I wanted to make these as small as possible so there are no nuts, the screw cuts its own thread
BOM for the case is
4 x 20mm M2 socket head bolt
2 x 5mm M2 flat head bolt
BOM for the case is
