Standard ATX PSU on NAOMI 2?
freddiefiasco
California, USA
Is it possible to repurpose a Standard ATX PC Power Supply for NAOMI 2 using a standard ATX PC power supply?
+12V, +3.3 and +5V can be obtained from both power supplies minus the POT adjuster.
Yes but you need an adapter that has as many wires from the atx connector run to the jvs connectors as possible so that you aren't starving the Naomi of amps.
If I am only planning on using the JST-8 and JST-6 connectors, will there be any kind of issues?
I'm basically wanting to use an ATX PSU to power up either a Triforce or NAOMI 2.
All other I/O and Hardware already being powered by other means.
PC power supply is what I'm using, along with Capcom I/O, and Naomi 2 works fine. First Naomi needs aux power, and won't boot on PC power supply alone if you're using an I/O.
atx atleast 150 watts or more has plenty of power for i/o jamma and naomi 2
