duffcon
I'm considering using a riddled TV switcher to put Tekken 2, 3 & tag into my Namco cabinet. The cab uses the onboard amplified audio, using the left channel from Jamma pin 10 and the right channel from the kick harness pin 1.
The switcher works by using Jamma pin 10 for audio left and 11 for audio right. It also has a header for these pins which I can use to jump the right channel from the kick harness and carry it out. My question is if the right channel comes from the kick harness, then what is "Audio (+)" as labeled on the pinout from the manual used for? Is it a duplicate right channel?
