Taito B System - Nastar color issue
Tailsnic Retroworks
Spain
Hi, I have discovered powering on my 2 Nastar boards that there are revisions with wrong color resistors values.
This is the correct Nastar:
And this is the bad Nastar: (darker)
The issue is with those 8 resistor values. They differ on each one of the boards, and they are home-soldered, no signs of external changes during its life:
The good values I have measured are (left to right):
33ohm
470ohm
33ohm
470ohm
33ohm
470ohm
33ohm
470ohm
The bad values I have measured are (left to right):
330ohm
470ohm
330ohm
470ohm
330ohm
470ohm
330ohm
470ohm
So, the conclusion is in the factory, there has been a mistake with the 33ohm resistors, and the bad one uses 10x value to 330ohm.
I'm going to exchange them and see if it works.
