Edit:
This is no longer a 'interest check' thread for pre-orders. as I'm just going to be doing the design work for these and then I'll be releasing the files so you can get your own cases laser cut at Razorlab/Pokono or the vendor of your choice. I'm doing this because:
There is a link to the approx prices for the plastics quoted by Razorlab in a post [here].
Please check later in the thread for development. I'll post a link to the finalised files here once complete.
Original Post:
I'm looking to get an acrylic case laser cut for my F3 Multi and I know a couple of others may be interested so I'm starting a thread to bash some ideas around and gauge interest.
I'm thinking of something like the following model:
There could be a couple of options. A) like the top part of the model with the selector LCD mounted on the underside of the case or B) with a plain top piece and then with a little enclosure for the selector LCD so it can be used remotely or in another case etc
I'm thinking 3mm red for the bottom of the unit and 3mm clear for the top so you can still see the PCB clearly
If possible I'll look to get the Darksoft and Taito F3 logos etched on top too.
The cutout to the right of the LCD selector on the top model is to feed the ribbon cable back through. I spoke to Darksoft about the potential of using right angle connectors but he's already got all of the parts for the selector LCDs so it's not really going to be an option at this point.
As with other projects I'll look to provide all the hardware in a kit so they can be easily assembled. The multi PCB will be mounted between Nylon spacers so there is no metal-metal contact and I'll see what I can do about souring some nice screws etc. I'll probably go with some threaded hex standoffs unless I can find some threaded round ones. I used hex ones on the Run-DMD frames (pic below) and they looked quite nice.
The design is in no way finalised though and I'm happy to listen to any ideas etc.
Pricing would depend on the amount I get made but assuming we get some decent numbers from previous experience I would take a guess that they would come in at around £35/$45 depending on options etc.
They should pack nice and flat for shipping and so they should be fairly inexpensive to ship.
Anyway, let me know if you have any ideas/input and if you are interested and I'll start to get some numbers together before sending off for some quotes
- I can release various versions with all holes cut for the selector PCB, partial holes cut for the selector PCB, no holes cut for the selector PCB etc etc. You can then mix and match which parts you want to have cut
- You can get your parts cut in what ever colours you want and you can buy whatever standoffs/feet etc
- I'm doing this non-profit and so I don't want to have to buy a load of stock in and risk not selling them or not buying enough and not being able to hook people up. This way, people can order one whenever they like as more are produced by Darksoft
- I don't have to deal with 1000 PMs sorting payment and shipping out
Not shipping them internationally should make them cheaper for y'all too.
Original Post:
