Bgm is good with the sound pot OK. But fx nothave you trieed stereo? also might wanna do a resistance test on the volume pot. could need a new one.
Thank you for the advice.... Bgm is no related to fx?Replace the capacitors on the board. The Sony baseboard is notorious for leaking caps causing power and sound problems.
I will Replace the smd caps on the Mother board. (near the pot audio). Gnet uses CF card btwI had a bloody roar zn1 boardset with no sound (fixed with reprogramming the eeproms on the romboard) Than low sfx/music. To fix this i replaced all of the smd caps on the rom board. Doing that will fix the issue let me know if this will fix it.
I Replace the smd caps with another ones, sitll nothing. I talked with the ebay seller hope to arrange an agreement to return the item.I had a bloody roar zn1 boardset with no sound (fixed with reprogramming the eeproms on the romboard) Than low sfx/music. To fix this i replaced all of the smd caps on the rom board. Doing that will fix the issue let me know if this will fix it.
