SOLD Taito Type X3 Puzzle & Dragons + FAST IO + Touchscreen monitor
PascalP
The Netherlands
Letting go of my spare TTX3 P&D unit + an original touch screen monitor coming from a P&D cab.
Not my type of game and I can't find the place to make a decent set-up for it.
So what's included:
- Taito Type X3 unit, fully working and original with P&D HDD and dongle €175
- Original HD touchscreen from P&D cab (+ EU PSU 220V) €125 (Sold)
- Taito Fast I/O PCB (SOLD)
All you need to add yourself is a RFID card reader to get a fully working setup :)
EDIT: decided to split up to pack, Fast I/O is already sold!
562526
553f30
553f31
553f32
Since you can't go on-line, the RFID card reader doesn't serve any purpose. Unless it's required on boot (I haven't tried disconnecting the one in my cab)?
i will hook everything up to verify if it is required or not.
If I recall correct it will not boot without it?
Tried opening up my cab to test and save you the trouble, but I have no idea how to get into the control panel area. I took off all the visible bolts, and it wiggles but won't actually come off :(.
Thanks! Can’t you just disconnect the JVS/USB on the TTX3 unit itself?
It definitely won't boot with the JVS I/O not being present, just tried.
Doesn't narrow down if the card reader is required or not though.
And what about the USB connection of the card reader?
For my other TTX3 unit with USF4, it is a red USB cable
I have no idea where the card reader's wired to. The only thing visible in the cab is the TTX3 itself. Fast I/O Main ethernet cable is plugged into it, and the JVS USB cable.
The JVS USB should be the card reader.
The Ethernet is Fast IO.
So I think we can confirm it doesn’t boot without a card reader, thanks for your help!
It will not boot with out a card reader.
Tjere is only one jvs device on that which is the card reader so the jvs/usb is directly connected to the card reader
Decided to split up to pack, Fast I/O is already sold!
- Taito Type X3 unit, fully working and original with P&D HDD and dongle €225
What would the shipping be for the screen to South Dakota, USA? Also how big is it? I assume the psu is capable of switching to 110v?
Just put the screen on my scale, and it is about 8 to 9 kgs, if i can keep the package below 10 kgs is would be €60 shipping
Here are some specs from LG's specsheet (Panel is a LG LM215WF3), so it will be slightly bigger in the metal enclosure ;)
Will get the exact measurements for you if you want
Active Screen Size 21.46 inches(545.22mm) diagonal
Outline Dimension 495.6(H) x 292.2(V) x 10.2(D) mm (Typ.)
Pixel Pitch 0.2475 mm x 0.2475mm
Pixel Format 1920 horiz. By 1080 vert. Pixels RGB stripes arrangement
Color Depth 16,7M colors (6bit + A-FRC)
Luminance, White 250 cd/m2 ( Center 1 Point, Typ.)
Viewing Angle(CR>10) View Angle Free (R/L 178(Typ.), U/D 178(Typ.))
