Taito Vewlix JVS IO
  • Thread starter Thread starter jassin000
  • Start date Start date
Anyone got the manual or pinouts for "K91X1245A - J9100641A"?
ASFAIK : the button loom "G1" connects into the edge connector and the USB cable to the TTX2 plugs into the USB port - does the card reader plug into the smaller USB port? the only picture I can find or one of this type of io connected up is for "K9101258A J9100647A" and it uses the large white 4-pin with Orange, Red, Black,Black wires (I assume the bottom two pins are GND - but what are the other two?).
I picked up a Diamond black and as it comes with absolutely nothing inside I wanted to use this spare io PCB instead of trying to source the correct JVS one for inside the panel.
@MetalliC released his JVS patch information for CvS2 to us today!
If you find his work useful/beneficial, please show your support by making a donation to the Dumping Union in his name.
Capcom vs. SNK 2 "010804" (GDL-0008D) JVS patched *.bin can be found here.
With this patch, CvS2 is completely playable/functional with both versions (1.00/2.00) of the Taito Vewlix JVS IO.
A very special thanks to @cpsystem3 for his assistance in this solution, you sooo rock! :thumbup:
Hello,
The link doesnt work anymore.
Could someone upload the Patch version ? I just bought my Naomi 2 :)
Thanks a lot
https://drive.google.com/file/d/1GQ0QfdNGdKPjUHgx2_284wKh9nE8L_pE/view
People still asking about this, so I went ahead and did it myself. Soak tested and it worked just fine on my JVS IO. This is for the NetDimm version. If I ruffled feathers on Twitter for my wording, I apologize. I bear no ill will towards AP (this is a pretty fringe case), but all ill will towards Discord.
Led you nowhere is a bit of a stretch when the hex values are posted in this thread.
MetalliC said:
patch is:
offset new_value old_value
00001AAA: 0B 0C
00001AD4: 0B 0C
00001B10: 0B 0C
this patch is for "World" CvS2 version, (GDL-0008 )
Also,
https://arcade.vastheman.com/dunion/#donate
