Tekken 3 Stuck at JVS Check (loops) when connected using JAMMA edge
suverman
Bulti Moyz
Multi Boyz
Calcutta, India
I just got 2 x Tekken 3 boards Namco 12, and trying to run through the JAMMA edge.
Both loop on JVS check counter and doesn't move forward.
Changing the switches dont work.
Am I missing something? :/
Probably won't make any difference, but there's a battery on the main board. You could try removing it.
Had exactly the same symptom once...
PCB was in a boot looping...
After changing the work RAM and re-flashing the game failed, the culprit turned out to be a corroded track...
May be this helps...
Good luck
Thanks, in my case it worked in my cabinate which has an arcade power supply with voltage cranked up a bit, but that problematic loop occurred on my Retroelektronik Supergun setup with a cooler master 500WATT ATX PSU. My supergun isn't really as good as the HAS/Sentinel which are available here so most probably the Namco System 12 wasnt getting enough voltage to run properly.
