Tekken7 FR problem.
thechop
Wolverhampton,England,UK.
I have a tekken 7 board set that is unmolested and as it should be with dongle, it has been working fine and then all of a sudden it crashed/froze mid game and now it boots up but only to the coloured chequerboard screen( which now has some lines in it) and then the windows boot screen comes up but then it goes blank screen and that’s it.
Is there anything I can try or does anyone have a clue what the problem might be.
thanks in advance
Pete.
Try reseating the video card and replace the 2032 batt when powered
also keep in mind that the hdd on these fail al lot. So that might be the big issue.
These are handshaked to the mobo
The checkered pattern with lines in it is clearly related to graphic card.
You can replace it with an identical model from another identical ES3, it might work. Most of the time it won't work because of bitlocker.
Contact me if you need some servicing.
