Time-sleuth replacement 3D printed case after Shapeways shutdown
hatmoose
New Zealand
Timesleuth is an awesome open source lag tester - its completely self contained and you can cook your own firmware to test your favourite resolutions (up to 5 resolutions switchable from the dial)
Make your own from the project page here
https://github.com/citrus3000psi/Time-Sleuth
Firmware page here
https://github.com/chriz2600/time-sleuth
Website implementation of firmware generator here
https://time-sleuth.i74.de/index.php
Sadly Shapeways has recently shut down and all data has been lost. This shell 3D printed shell is a replacement for the one that was lost when Shapeways shut down.
Screenshot 2025-01-09 at 8.01.17 PM.pngScreenshot 2025-01-09 at 8.00.49 PM.png
Prints without supports on just about anything, in just about any material, with just about any settings - this one came out nicely on my ancient ender 3 pro with creality "hyper" PLA. Assembly with 4 x M2 x 20mm bolts - 4mm heads. Depending on your printer you might need to pick some stray filament out of the bolt holes.
Please take extreme care to ensure that the bolts are 20mm or shorter, if they are longer than 20mm they will poke out the bottom of the case, and the bottom of the case rests against the screen
Wrong - 22mm bolt tip pokes out bottom of case where it might scratch the screen
Right - 20mm bolt tip safely inside case (14, 16, 18mm also OK)
STLs in attached .zip "Timesleuth 3D printed shell.zip"
