Timeharvest USB supergun compatibility list
Ms. Tea
Canada
I bought one of the Timeharvest USB superguns awhile back. I haven't seen anyone post a compatibility list, so I figured I'd put together what I've tested. If anyone has any information to contribute, I'm glad to add it to my post. For context, I've tested on the USB Cbox 3.0; I don't know if the other models have different compatibility.
GamepadCompatible?Samples testedCbox tested
Xbox One S (bluetooth)No2USB Supergun/cbox ver. 3.0
PS3 SixAxisNo1USB Supergun/cbox ver. 3.0
PS4Yes1USB Supergun/cbox ver. 3.0
Sega Saturn USB (original)No1USB Supergun/cbox ver. 3.0
PS2 to Xbox 360 (wired)Yes1USB Supergun/cbox ver. 3.0
PS2 to PS3 (wired)No1USB Supergun/cbox ver. 3.0
8bitdo S30 DIY (Saturn)Yes1USB Supergun/cbox ver. 3.0
Switch ProNo1USB Supergun/cbox ver. 3.0
Brook Wingman SD (USB output mode)Yes2USB Supergun/cbox ver. 3.0
8bitdo Xbox One Pro 2Yes1AES USB cbox
Mayflash universal adapterYes1AES USB cbox
8bitdo arcade stick (xinput mode)Yes1USB Supergun/cbox ver. 4.0
I don't know if it's the same hardware, but I have one of the Timeharvest AES shelled CMVS units with USB ports. The only controller that worked straight off was the 8bitdo Xbox one Pro 2 wired controller. However, with the Mayflash Universal Adapter (blue shell) I could get a few more controllers to work when set to PS3/Directinput mode. I tried a Logitech F710 and a Razer Wolverine V2 and they worked well with it, wouldn't work plugged straight into the CMVS.
I have better controllers to test, but I really just wanted to play some Last Resort last night.
CBox 4.0 works fine with 8bitdo arcade stick in Xinput mode. Can also confirm dualshock4 works fine with a Magic-NS adapter
I have one of these CBOXs and Mayflash F500 arcade sticks work out of the box in PC mode.
Y'know what? L1/L2 don't work on my dualshock4 or my 8bitdo with the cbox 4.0.
R1 and R2 work. I actually can't even assign either of the L buttons to anything!
Very weird.
I'll try it out on mine later and see what happens.
Edit:
I tested it out and function is exactly as you describe. L buttons are ignored.
I'm not sure this matters too much, but it is good to know.
What is an sn30 diy (Saturn) kit?
I'm aware of the sn30, that's the 8bitdo SNES controller.
I'm also aware of the Saturn diy kit.
I have both.
Is that a typo or do I not know what I think I know?
Thanks for the feedback. I've started adding the other devices people have tested, and added a new column to the list with which cbox(es) people have tested with.
8bitdo retro receiver v1 and v2 both work.
8bitdo m30 2.4g works as well.
Thanks! Can you two let me know which cbox you were trying with?
I have both.
It's a typo. The Saturn DIY kit is the S30, and that's what I meant. Fixed.
