TTX2 and Mitsu JVS IO helper PCB
tom5151
Luxembourg
Hi guys,
Is it possible to use Mitsu JVS IO helper PCB with a TTX2 ?
If yes, which IO board would be recommended ?
Sega rev 1 ? rev 2 ? type 3 ?
So I have a TTX2 booting Niko's multi, a Sega i/o type 1 and Mitsu's JVS IO helper PCB.
Everything works fine, but I must be stupid, I don't find the way to enter test menu.
I don't have a cab and no supergun for the ttx2.
Just the IO helper on which I plug my pad and the ttx2 vga plugged on the LCD.
Connect pin 43 of the IO to ground
Yeah the S-JIHP is just a pass-through so you would enter the test menu the same as you normally would with a pcb.
Thanks guys for your reply :thumbsup:
As my Sega io type 1 is wired to S-JIHP with 60-pin cable, do I need to solder on Sega io board or on S-JIHP ?
Sorry for the stupid question , but I'm a real noob in soldering stuff :whistling:
The test pin is on the DB25 connector. So you wire it up just like the other controls.
