TTX2 multigame - linking up two cabs via ethernet? (and SSFIV 2p question)
mltv
northern NJ - about 30min from NYC
Hi, has anyone tried linking up SSFIV on the TTX2 multigame with two separate cabs? (using ethernet, and setting one as master, and the other as slave - assuming I can use the onboard ethernet and dont need a special IO card) Each cab is a single player panel with a ttx2 w/ multigame. Optionally, has anyone gotten SSFIV 2player to work on the same cab? Mine crashes when 2p is selected. So, Im hoping for either - linking up 2 separate cabs, or just getting 2player to work on one cab.
Linking works just need to configure the network from the test menu. Also a switch or crossover cable may be needed.
Any two player versions of 2012 floating around? I've only seen 2 player version of 1.0 on the net to download.
