Liquidus0
Montreal
UPDATE : Capacitors are busted. ebay refunded the unit after a week. No answer from Yaton
I bought recently a unit from arcadefunny (Yaton) on ebay.
https://www.ebay.com/itm/402757309959
It came NOS, looks untouched. A friend brought me a HDD to make a multi with it.
I plugged it in a NNC, with a DVI to VGA converter, audio 3.5mm and the JVS USB cable in the JAMMA port. But when I power it up, nothing is displayed and I can't hear a thing.
2 red lights light up in the Type X, the green one on the back
and the yellow one under flashes a couple of time then shut.
Did a reseat of the ATI card, unplugged/replugged cables inside and outside, and nothing.
Then I tried it in a Blast with the Capcom JVS/JAMMA adapter, plugged it in the VGA slot for 15kHz, and still nothing.
I couldn't find any video of a multi booting up to see what's the menu, so I could try to blindly navigate and boot a game and hear if sound is working or not.
Another odd thing is that randomly, after 3 minutes, the Type X powers down and restart itself without touching anything. I pushed the test and service buttons also and it did the same thing after 3 minutes.
Any help/comment will be appreciated. Thanks !
I forgot to mention that I looked a the dip switch. I read they do nothing, but the 1st and 5th ones were on. Put them in off position and it did nothing.
Also, the model is a 022A.
Do you get any beeps?
Honestly it sounds like it might be DOA. How do the caps look around the CPU?
I bought recently a unit from arcadefunny on ebay.
Ignore the DVI port and just plug into the VGA port and connect the VGA cable to your IO adaptor. Wait about a minute and you should the PC load on your display. 15 & 31kHz via the VGA and DVI ports respectively.
Tried that and there was no image, no sound either.
No beeps. One of my friend took a look at it and discover that some capacitors are blown.
I found another Type X, this time from Stefano Bruni webstore.
This one doesn't boot. To be more specific, it's continuously trying to boot each 10 seconds or so.
View: https://www.youtube.com/watch?v=fxz5ceH5Ez4
The red LED near the I/O stays on when it's plugged, but the one near the ram and in the back of the unit are shutting off when it's boot looping.
I already cleaned the ram and the graphic card with Deoxit and reseat them.
This one is a 021A model.
Please see my thread over in the Repair Logs forum for more ideas. I had bad caps on my board, too. Your symptoms sound very close to what mine were after I tried to repair mine initially. So, I had to go back and figure out where I went wrong.
