Link no longer working..are these time sensitive?Just updated my Lord of the Vermillion with the B23 bios @300wins posted. I did this within Windows while running the Artax v4 multi.
You need to download the "Aptio 4 AMI Firmware Update Utility" from here
https://www.ami.com/products/firmware-tools-and-utilities/bios-uefi-utilities/
Extract it and copy over the "AfuWin64" folder to a USB drive as well at the full B23 bios dump that's been posted. Next run your TTX3 with multi and once in the menu scroll over to the utilities and launch explorer. I plugged in my keyboard/mouse and USB drive and copied the "AfuWin64" to the desktop and ran it. I used the settings in the picture posted below and waited for it to flash and reboot. It took a little longer to come back on, I think, but it worked fine. Now I wish I would have tried via DOS first, but I imagine it would work that way as well.
Thank you for ALL of the help Murray.AMI just like to fuck with everyone every few years and update their website so all links from all history no longer work.... just because they can.... and they like to hire web developers who skipped the lesson on 301 redirects.
https://www.ami.com/bios-uefi-utilities/
Make sure you use APtio 4
Hi guys,
I have updated my X3 with B23 bios that 300wins posted using "AfuWin64" . flashed using the Artax v4 multi with the explorer option on the utilities.
But now my X3 always reboots 2 times before start really booting. Anyone have a similar issue? Also its seems that always looses the BIOS configurations that I have modified like the date. I have already changes the bios battery.
Any sugestions???
Per @chunksinThanks very much to everyone involved in getting this new version of firmware for us to use
One thing I noticed afterwards is a very slow boot time, this is due to the Intel Management Engine and the secondary network interface, both can be safely disabled in Device Manager. I tried to find a compatible driver but had no luck, maybe there is a BIOS setting I missed to enable or disable the Intel MEI?
This. 100%Per @chunksin
Disable the Intel Management Engine and the Secondary Network Interface from the Device Manager from within windows and the boot up will be speedy again.
It seems that like its restoring or recovering BIOS config or something similar.Try what was suggested, but i'm not sure that losing the bios settings and the unit rebooting itself twice before booting properly each time is caused by that. I believe it just makes it boot slower.
I've flashed 3 units so far, using explorer on Artax v4 and none of the 3 units i flashed have had any issues, including slow booting after flash. I didn't get this slow booting thing after flashing the unit, with FASTIO or JVS as the io board.
My only advice would be to try and flash the unit again, and make sure you have the settings exactly as muckyfingers posted in his original post. It shouldn't hurt to flash the same bios image again over the top.
What game was your unit originally? Just out of curiosity? I've flashed LOV and Gunslinger 3 original units and had no issues, so i'm not sure why the IME and secondary network are causing slow boot issues for people.
I Have. I’ve not encountered any issues.I have personally flash several X3 with no issue. I've done Puzzle & Dragons, Lord of Vermillion, Left4Dead, Gunslinger Stratos. I have never done a FF Theatherythm though.
Thanks i will try itUTILS>>CONTROL PANEL>>DEVICE MANAGER>
You should see the two devices with exclamation marks like i posted the pictures a few posts back. Just disable both of them devices, right click disable. Should make it better, they won't effect performance but one of your LAN ports will no longer work.
Can confirm, I’ve done three upgrades with the 780The driver should be in the Artax version. At least from the cards I have installed, it automatically installed the proper drivers. You'll need to reboot, but once that is done, it *should* be the correct video driver. I can confirm this for a GTX 780.
