Vampire Savior sound problem
TheBortot
Rio de Janeiro, Brazil
Hello, the sound of this game is strange: they are getting out in the wrong situation, like in the character select, the sound of characters being hit is heard; when i see the intro, the there are so many sounds from different situations along the game, like the sound of projectiles, a ``KO`` sound in the middle of the battle,etc. It`s not an A board problem.
It`s a memory issue? what memory i should change? i have 0 experience with them, the same with burning one or programming. What i should learn? Or could someone burn it?
Dunno why, but the video i`ve recorded got no sound, lol.
Images of pcb:
https://uploaddeimagens.com.br/imagens/darkstalkers_3_2-jpg
https://uploaddeimagens.com.br/imagens/darkstalkers3-jpg
The sound ROMs are either bad or incorrect would be my guess, has the board been desuicided?
If not, it's possible it's a sign the battery has died and it's on the way to suicide
If it is still on a battery and it was dead it would not boot at all. The battery will not give any indication it is about to fail. Battery has no affect on sound.
i checked if all the memories are ok at the menu service and all are ok. So it`s a baterry issue them? Not suicied, all original.
No, the service menu tests don't really tell you a lot, you really need to test them off board - I don't believe it's an A board issue but to rule it out have you tried it on another A board?
Other than that I've only ever heard of sounds being out of place or random sounds appearing in game at one other time and that was on a Mortal Kombat boardset, and I don't believe they found a fix for it
