Tuanny
Hi guys got a 2p vewlix panel from alberto1225 here, its not sitting flushed how would i go about fixing the problem. its bulging a bit in the middle/sides. seems to be fine when i flip the panel over as its all flushed. not sure if the screws are touching the holes causing it to bulge tried sanding the hole a bit to make it bigger but didnt seem like it did much. its an original taito black cab
https://streamable.com/qtye7v
https://streamable.com/kamm8b
KinG_SoPa
Florida
Hey i have a DB as well, did you just receive the panel? If so put a couple of medium books across it for a day or 2 so it cab stay flat.
Tuanny
yah i finally got it to stay flat/flushed.
looks to be flat when i put the panel on the table but for some reason it not staying flat when i try to put it on the machine.
so i mounted the first set of screws from the left side and started to bend the panel with a good amount of force until it stayed flat then i put the next set of screws and work my way down bending each section to the right until everything sits flat.
